s&n fab 3 seat bravo revamp
probably just a regular 60 housing that s&n welded 9" housing ends on
Problem with that is virtually no one does, or atleast used to make semi-float, 8-lug shafts.
no it was originally a van housing
c clip is :rb:
he needs to do a semi float conversion on the rear
So 35-spline, SF C-clip Van unit like I thought. Did he narrow one side or does he run it offset? Can't tell from the pictures but it looks centered.
Hes running a c clip rear?
Big Mark runs the same rear end in his rig. Sure its :rb: C-clip, but the shafts are *almost* unbreakable and dirt cheap (as is the whole rear end). If I had one kicking around I'd be seriously considering it. But I don't, and last time I was at the PnP I didn't see a single one.
Cadaliac grills......look at the oil my Cadaliac spills:haha:
:haha::haha::haha:Awesome!:awesomework:
Car looks good Nate.......Hey? Can I leave the ToyBug at your house? Promise, you just have to help me rotate the tires:;......nothing more.:redneck:
i think its centered i dont remember anymore
Those van c clip rears have un equal length shafts, we cut down the long side to short shaft length, something like 2 1/2", its now a 63" housing. Not bad $75 pull apart housing with shafts, $15 pull apart shaft. $100 63" 35 spline rear 60, not bad
some more progress today after sleeping in until 12
shock mounts all tacked up
new winch mount in
front shock towers reconnected to the frame
Looking good. Save yourself some headache with the rear shock mounts and don't weld the outer mounts until everything else in the back of the chassis is welded.
I welded everything in the lower half the chassis first than changed the rear diagnol down tubes and it pulled those mounts out almost an 1/8" makes it a real pain for the bolts to slide in. I even had a brace tacked in to stop the chassis from flexing and the mounts bolted together with spacers. It just sprung out of alignment when they got pulled out.
thanks pook that helped today
will get todays progress pics up in a minute just waiting for the cam to charge
pics from today
welded everything up
re mount exhaust in the back
finished up the front bumper bar
cut the plate for the front winch mount and tacked it in
started radiator mount and tacked in
decide to start on the firewall so we cut out the pass corner for im proved vis
and added a tube for more support and to mount to
also got the trans cooler mount almost done
more
bender is on loan from jason c not sure what brand it is air over hydro
same bender that was used at sn fab for years
