codyy
Member
yes i am interested but would hve money for 2 moths i paying 800 a month on my quad right now so i can start this sooner what do you want for them if you still got them
few more sorry ,might be helpfull....
i question that too. thinking/wanting to do the same.when i do the fuel injection v8 what do i do for fuel system. can i take a toyota tank from fuel injection tand use all high pressure line and same pump?
You can use the stock toyota tank, just wire in an external pump. TBI only needs like 15 psi, those pumps are cheap a napa. Put the pump as close to the tank as possible.
an FI toy pump will do that easily. for sure theres enough pressure. im guessing it will flow plenty too. i'll find out soon:redneck:If hes still using the toy in tank pump why not put the high pressure pump closer to the engine? A 5.0 fi engine needs at least 30 psi fuel pressure. Personally, I say go with propane.
