My Bus,,, My Bus,,, My Bus...
At the top you can see how the wiring loom goes on and you can get an idea of the sofa/bunk will work out...
Here's the carpet transition strip I picked up... Came in 12' sticks... I had to drill the holes bigger so I could use #8 pan head sheet metal screws... You can also see the counter top color and some sticker goo I still need to clean off...
Got the strips in and the trim for the window... Need to start on the other side now... Then install the bunks and carpet them... It's getting cozy...
You can see the damage to the counter top on the top of the back splash in the last pic... It about 4" long right next to the extension cord..
Got the wall finished up behind the head and removed the galley to insulate behind it... I'll finish up the galley and upper cab then paint them before they go back in...
Got the wall behind the galley sheeted... Cut the counter top for the stove and sink... Started painting the galley today... Gonna carpet around the window and to the right of the stove then install diamond plate aluminum behind the stove...
seen this rig headed to the bremerton raceway today. made me think of yours.
said fraidenburg racing on it. it was haulin ass too!
That thing must be 15' longer than mine, with that trailer it's probably a bitch in parking lots... How fast was it going???
in the pic I was just barely taking him going 67mph, he was cookin along after this pic is a little hill and he didnt slow a bit. who knows whats under the hood, he is a drag racer dude. he was by no means going slow.
