Another lil something.....
I cut the rear air bump cans out. with the shitty welds it was pretty simple :haha:
So I swapped the air bumps front/rear. I also ended up needing to raise the contact tower for the rears.
And now no rubbing :cheer:
A little ditch testing :redneck:
So since I am waiting for the last load of tin I went ahead and made a cover for this.
Something else I found, I was getting drips of power steering fluid and finally found a pinhole at the ram fitting. I suspect it was a simple defect and pulled the ram and had james weld it up for me..
Got the second panel done.
Next started working on the side skins.
Both skins are done :bbbball:
Next onto the roof.......
Matt had requested some grab handles to help getting in/out. I personally love a well place grab handle :bbbball:
So I decided to paint the roof panel black. I thought it would change the look and it certainly set it off. :cheer:
so apon some testing I found a clearance issue between the front pinion yoke and the oil pan skid.
So luckily the skid unbolts and thank goodness I pulled it because guess what--bolts were fawked up and loose at the rear mounting location.
So it wasn't too hard to modify the skid for clearance.
Once done I took it to the same spot and have about 1/4" clearance now.
So the last thing to do is get the shocks and air bumps charged and then its ready.
