baldduck74
- Joined
- Oct 19, 2013
- Messages
- 380
All this, so I can totally **** up my floor and firewall. I know in my head how I want i to be, but will never be able to make the goal.
Brings new meaning to Heavy Duty IntakeSo, figured Id slowly start working on the S10 again want to do floors and firewall next. Then thought don't have intake figure out yet.
So, had the 90°s but no 4" tube, 80s model Chevy Square body has a 4" drive shaft in case you need to know. Ithought it would be temporary it's not going to be.
Everything is poly mounted, the 2 90°s are silicon. Body will be welded to the sliders, and cage.Is your engine solid mounted? How about the body? Seems like you would want the intake mounted to the engine, not the body?
Good to see some progress being made.Just a picture showing I've been working on it, and I will say the struggle is real!
Still got a way to go, this sheet metal work is really testing my patience
I was worried it wouldn't, but brake lines should clear just fine.
That's a cool setup!Not exactly S10 related yet!
Built a swing out generator mount that will clear camper door, hated having it without a spot. Got to get a shorter pivot bolt
Thank youThat's a cool setup!
Time to sit in the drivers seat and make motor noises to get remotivatedBad thoughts, been thinking about parting it out.
I've stepped away and just been ordering parts, worked on it a little bit last weekend it was same old sinerio, more work created. Don't know how it's gonna go.
I tried that today, threw a rod and broke transmission in halfTime to sit in the drivers seat and make motor noises to get remotivated
Ha you sure are hard on parts!I tried that today, threw a rod and broke transmission in half
