351w cam
fordcontraption01 said:
Ive never had anything on propane got a buddy that runs it on his 350 it is a new motor msd ignition and a new kit and sometimes not all the time it pops and cracks plus i get a headache for two days after being behind him. My setup is a cobra intake with a b303 cam trick flow ported heads with 24 lbs injectors 70mm throttle bodie and a pro m bullet mass air meter stock a9l computer with all the egr cut out of the harnesss and it will smoke the 47s off it dont surge and carry on like some due either as good a luck that ive had with this setup now i would not do anything else.
My factory efi is speed density. Did you convert to a MAF setup or was it factory on your motor?
here it is
