Newbies Post Up Here - Rig Specs & Info Thread
  • Thread starter Thread starter P
  • Start date Start date
My name is Josh. I live in Columbia. Looking forward to learning and enjoying everyones posts!
See specs below!
Well, I'm new to the forum. I've snooped around here for information for a while now, and figured I may as well join. I've been fooling around with a buggy build for the last year or so, and I'm just about ready to take it out for it's first catastrophic failure. Not much WOW factor, but I think it'll do ok for my first attempt at a ground up build.
Build Specs:
1-3/4"/.120" DOM & 2"X3" - 3/16" TUBE
'04 LM7 5.3 DBW - REFLASHED BLUE/GREEN PCM
4L65 DERALE COOLER W/8"FAN
'97 F350 D60RS FRONT
FULL SPOOL W/4.56:1 R&P/1350 YOKE
35 SPLINE/4340 INNER-OUTER SHAFTS
POLY DRIVE FLANGES
PCS FULL HYDRO STEERING (SINGLE)
D60HD FF REAR HOUSING
35 SPLINE 4340 SHAFTS
4.56'S AND FULL SPOOL/1350 YOKE
DISC CONVERSION
DBL TRIANGULATED FOUR LINKS FRONT/REAR
16" KING 2.0 EMULSION COILOVERS
4" AIR BUMPS UP FRONT
SUPERWINCH LP8500 TUGGER
24" BELLY HEIGHT
120" WHEEL BASE
RECENTERED H-1'S W/ ROCK RINGS AND INSERTS
18/44-16.5 TSL BOGGERS
NP241C W/JB CONVERSIONS SYE & H.D. CHAIN
SCAT SEATS W/4 POINT HARNESSES
Been on here for awhile. Ride mostly in the Chattanooga area. 99 XJ, 79 ford 60, 14 bolt, 5;38's, 37's, 3 linked front..
Build Specs:
POLY DRIVE FLANGES
DISC CONVERSION
24" BELLY HEIGHT
120" WHEEL BASE
Thats a sick looking chassis !! way different than anything else
Just joined up, this is my current wheeler, a '99 XJ on 33's. It has been evolving over the last 8 or so years, and was my DD until about 2 years ago. Now l am wanting more so a buggy build is in the near future.
xjmarc said:
Always nice to see another XJ. Just curious how and where you attached the bars on the A pillar.
The a pillar and inner fender structure was plated with 3/16" and then the tube welded to them. There are also tube clamps just below where the tube drop thru the fender so the whole outer portion of the cage can be removed.
i posted this once dont know if it ever made it but this is my project it has a partial 84 regular cab frame rest is caged and putting 4 link rear just got it installed, undecided on 3 or 4 link for front, putting 2.0 FOA coilovers 14 front 16 rear, 3.4l v6 toyota motor, undecided on dual tcases or creeper gear, but the main goal is to stay all toyota to see how it will work out as a cage buggy and how much abuse it will take,
Here is my everyday yota, i am waiting on a set of pipe bender dies to put a exo-cage on it
High :afro:'s. My name is Brian.Been on here about a year 1/2. Been building a one ton yj for the same amount of time. (Poor and slow makes for a long build time). But anyway here's the run down. Dana 60 front chrome moly inner and outers, c&m drive flange, 14 bolt rear, twin stick 205, 42" irocks. This is my first build of this magnatude. Probably be a mall crawler for a few months (if it ever gets finished) :P
Re: Re: Newbies Post Up Here - Rig Specs & Info Thread
AKA Zukitough Racing on the Facebook. 90 Suzuki samurai, stock motor 'cept custom header and air cleaner, stock transmission, 6.5 to 1 t-case, 4 runner driveshafts retubed with schedule 80 1/4" thick pipe, Toyota axles, full hydro steer front, longfield shafts, alloy USA cro-mo rear axle shafts, 4 link front, wishbone 3 link rear, ballistic fab 3" ends, 5 gal tank, Wilson Off Road of Fayetteville, NC did cage work and some fab, i did frame extension and body work, 5.29 gears in the axles, Spartan locker front, spool rear. 42" swampers now but did have 44" boggers and 39.5 cut boggers
About me: 36, been Active duty US Army for 17 years, spent most of my time at Ft. Bragg, NC, now stationed in Ft. Irwin, CA just 80 miles north of Johnson Valley, King of Hammers race grounds.
sent by my transformer because i hate typing
Eric from Kent, OH.
Here is my '83 Blazer
-6.2 diesel engine with Banks Sidewinder turbo
- '91 Dana 60 front axle w/ Yukon spartan locker. 4:10 gears
- 14b FF rearend. Grizzly locker, Ruff Stuff disc conversion.
- ORD Stainless braided brake lines all around.
-SM465 4 Speed trans
-NP205 transfer case - JB Fab twin stick shifters
-4" lift
-39.5" x 13.5r16.5 Super Swamper IROK
-H1 Humvee beadlock wheels - welded in pressed centers + rock rings + PVC beadlock inserts
-ORD engine crossmember
-ORD Steering brace kit
-Lee ported power steering pump and hydro assist
-Crossover and high steer built from 1/4" wall DOM
And my '87 Samurai
lockrite in the rear, SOA suspension lift, and a $5 2bbl Holley carb on 31" LTBs
This will become my crawler. I've got the 6.5 tcase gears, snatch tcase cradle, 85 toy axles being prepped to go in.
Not sure if I will link this one w/ fox shocks or stick w/ leaf springs.
