krackem
Build-Bend-Weld-Break -Repeat
OK so brack ground 85 4runner truggy locked front and rear and just done duals w/ 2.28 f & 4.7 rear 5.29s in axles ,and still leafs all around . Before I done the case swap I was axle wrapping bad in the rear now I know it will be worse with with the duals so I'm building an antiwrap bar ( some call it traction bar, pan hard bar, yada yada yada call it what you want stops axle wrap) my real question is there a place that's best to place it on the rear axle. Closest to center, or just were ever itll fit . Cause I'm doing a Y bar johnny joint front and 2 bushings on the bracket for the axle I just wanted some input
