Hey guys, Great site. I love the buggies on here. I from East Texas. I have two Toyota type rigs. One of them is the wife's rig. It is nice having both rigs. "The trip isn't over as long as one is still going." I have a little 3 seater buggy, and the wife has a '91 yota truck.
Pics and specs of my buggy.
Chassis:
1.5" .120 wall Full DOM chassis
Powder coated gloss black and Cleared
Twisted customs Fiberglass Liberty hood and grill (gloss black, cleared & polished)
Polycarbonate skins w/ Quarter turn Dzuz fasteners
Black 1/2" UHMV skids
Engine:
Fresh 22RE
Propane conversion from Gotpropane.com
LC Engineering performer camshaft
Comp cams Rockers and lifters
PSC billet aluminum under drive system (improves steering at lower rpm's)
LCE Street performer header
Borla Exhaust
K&N Filter Kit
LCE Red valve cover
Block was also cleaned and painted.
Transmission:
Low mileage W56 5 speed
Fresh clutch when installed
Transfer case:
Dual Ultimate Crawler (over 200:1)
Marlin MC07 Adapter, rotated for clearance.
23 spline
Front case has stock gearing (single stick)
Rear case has the Marlin 4.7:1 Crawler gears w/ twin stick
Axles:
Front:
85 Toyota 8"
Completely rebuilt (housing polished and powder coated)
30 Spline Longfield Chromoly Shafts
Complete Marlin Crawler high-pinion 3rd member
With 4.88 gears and ARB air locker
Spidertrax 1.5" wheel spacers
Rear:
86 IFS Toyota
Complete Marlin Crawler V6 3rd member
SKY Disc conversion
Suspension: (109" wheelbase)
All links are Powder coated and cleared
Grade 8 hardware with nylon lock nuts on all
Front:
3-link with panhard
1 ¾ .250 wall DOM lowers w/ Currie Johnny joints
1 ¼ .250 wall DOM upper w/ ¾ FK Heims
Sway-A-Way 2.0 Racerunner Air shocks (16" Travel)
Sway-A-Way 2.0 Racerunner Air bumps (4")
Front tire can be lifted 52" off the ground before any of the other 3 lift.
Rear:
Double triangulated 4-link
1 ¼ .250 wall DOM uppers w/ ¾ FK Heims
Rear tire can be lifted 61" off the ground before and of the other 3 lift.
Steering:
Complete PSC full hydraulic
High displacement pump
7.5 C.I Load reaction control valve (3.5 lock to lock)
2.5" Double ended ram
Aluminum reservoir
Billet Underdrive pulley
Teflon lined Stainless steel hoses
Tires & wheels
5-17x9 Walker Evans Beadlocks w/ wide rings (red)
5- Brand new 37"Red Label Krawlers (Spare built into chassis design)
Misc
Warn 9.0 RC comp winch up front
Warn XT 2.5 Winch in the rear (syn cable also) (Both have console mounted controllers)
Be Cool Aluminum radiator
W/ Be cool Electric fans
ARB mini compressor w/ small air tank built into chassis
2 8 Gallon propane tank mounted behind the seats
Optima Blue top
Painless breakered switch/ Keyed ignition panel.
Mastercraft Baja RS Seats with five points
14" KIRKEY CHILD SEAT
Autometer Ultra Lite 2 guages (speedo, tach, oil pressure, temp & volts)
Line X'd Interior.
Rear line lock
All Teflon lined stainless steel brake lines.
Hella Black Magic 8" headlights
LED turn signals and brake lights
Wife's '91 yota truck
- Wheelbase stretched to 108 inches.
- Custom coil suspension Front features a missing link set-up and the Rear uses a 3 link wishbone.
- Front Kingpin Dana 60 with 35 spline cromemolly shafts and warn premo hubs. inside are 5.86 gears and a Detroit.
- Rear matches the front Dana 60 35 spline cromemolly, 5.86, and a Detroit
- Front and Rear Poison spider diff protection ring
- Single t-case with 4.7:1 Marlin (total reduction 108:1)
- Poison spider cross over arms w/cromemolly double sleeved steering links.
- Attached to a red neck ram hydro steering setup.
- ARB Front bumper
- Warn 9500 winch with synthetic rope
- 38.5x14.5 r 15 Swampers SX'S
- 15X12 Bead locks
- 4 wheel disc breaks run off a ford f-350 master
- Custom flat bed
- Budbuilt Cross member
- Aluminum bed mount fuel cell
- Pair of besttop bucket seats
- CD player, CB, Pair of Subs, ECT.
Picture of the wife modeling a buddies rig
