rpf500
Guys,
I can't afford air bumps at this time. I need to add some type of bumps stops though. With my rig being 4 linked it's a little more difficult than adding normal YJ bumps back to the frame. I plan to change the suspension some this winter, so that is another reason to not buy air bumps yet.
TacomaJD sent me a pic of his and they looked like a good option for my front. The rear I am struggling with still. The PO had an "exo cage" type bar following the fender line and that was his "bump stop". I added comp corners and removed the bar that didn't look nor work well for bumps. On the front he had bumps set up off the frame that hit the top of the lower link. I don't really like that idea but maybe it's a good idea, not sure??
Also, I see a lot of center placed single limit straps. I have (1) on each corner currently. Both of which need to be shorter. Can I go with (1) in the center or do you all run (1) on each corner. I will get some close up pics tonight. I will try to post some random ones I have on my computer now.
