SECOND CHANCE RIG & Second Chance 2.0
Re: SECOND CHANCE RIG
Rohlingoffroad said:
i started to let brandon drive mine but I was scared it could last threw to runs and brandon is rough on rentals :popcorn:
hahaha Josh your rig looks like it will hold up pretty good, you put put a straight up BEAT DOWN on that thing on Cable :woot:
if I was in front of u on the line up I would have let u run mine but I still don't have a lot of confidence in it just yet because I wanted to get my run for sure lol
throttlejunkie said:
Your Dana 300 seemed to take a beating. What all do you have done to it?
Great job on your buggy, great awareness for your cause!
Pretty sure he took it out and put in a 205 with a ford front output, I love that little buggy!!!!
He is right the 300 was replaced with a 205 and 32 spline shafts with 1350 yokes. I got tired of replacing the 300. Only thing that really broke was a 1310 joint at the pillow block that is now going to a 1410 and the 4 bolts in the D/S high steer arm. thumb.gif
Also thank you for the pics ScottsPics loller.gif :dblthumb:
Rush Off Road 4-18-15
No issues with the pins ran them since 2007. Also thanks for the pic from Rush not the way I wanted to end up but what I get for not checking the trans fluid.
