Things I got done today and was to lazy to take pictures
Drilled and tapped brake calipers for 1/8 pipe thread
Rebuilt 2 brake master cylinders.
Set up pinion brakes with proper spacing and grade 8 hardware.
Finalized plumbing for propane with blow off and t for two tanks.
Nut and bolted about a third of it with grade 5 or 8 hardware and nylock nuts
Got some interior.
List of things to do:
Secure brake lines
Change springs
Rotor guards
Axle boots
Charge shocks
Master kill switch
Exhaust
Lights
Engine cage
Skid plate
I am stupid happy with how this turned out. It feels and looks very compact in person. I think the only regret I have at this point was not incorporating rear steer into the original build. Other than that, I am happier than josh on a Honda Davidson, Eric at all you can eat sushi, plowboy flipped over, John G having something painted purple, and bug-e j joining the bat mobile fan club combined.
Measured today this is with 8 inches of shaft showing on front and 9.5 on rear, with 16 inch shocks.
The front axle has 6 inches of up travel, if the axle stays flat with the frame. With an additional 2 inches for the axle to articulate up past bumps.
Wheel base 120
Overall length. 160
Height. 76
Width. 90
Belly. 19
Some spension pics.
What spring do you have and what do you need? My buggy sits about 2" too high with 200x16 over 250 18s front and 175x16 over 200x18 rear. I'd pay shipping if we trading any would benefit us both.
Rig is in storage for a couple of months. :'(
The only spring that you would want would be 250x16 but you would need the little keeper spring. I'll post all my used springs on here when I get home.
[quote author=Eddyj Other than that, I am happier than josh on a Honda Davidson, Eric at all you can eat sushi, plowboy flipped over, John G having something painted purple, and bug-e j joining the bat mobile fan club combined.
[/quote]
Sorry about going to storage but, that's HILARIOUS :rolf: :rolf: that's a bunch of happy! ! :****:
No reason for posting I just like to look at my junk.
Rig looks great , you should or prolly will wanna put some sort of guard under your brake rotors, they break easily if a rock hits them
