Mortalis5509
Re: Re: Ls motors
Since ls engines are push rod i thought they were better for low end tq vs a Ford overhead cam is better from mid range and on?jccarter1 said:I would definitely look at different t-case bc even with a 6.0, ls motors don't make good low end torque they really like the high rev's. Swap to a 3.8 for a 6.0 or a 4.3 for your 4.8 and it will be good mix of low end and wheel speed with the high rpm's of the ls
