zjtrey
i broke stock 60 outer shaft first ride out with bald 38 tsl's and weak 4.0L... i've seen many stock knuckles break so i won't run them without some gusseting... broken knuckles are one of the worst failures to happen in the woods...
i meant to mention that spicer 60 u joints are really tough but i recommend changing them every other year if you're beating on it as i've had them break and ruin the shafts... cheap u joint breaks 300 bucks worth of chromo axles...shittay!
