"****" AKA TBItoy said:How is your HP efi set up? What all sensors are you running on the engine to get your inputs? What ignition set up?
it has multiport Victor jr manifold 1000cfm tb with PWM iac
runs sequential
48lbs holley injectors
holley 60-2 crank trigger
msd pro billet with diy cam sync sensor
msd 6al
still run plug wires from dist.
cop is just plug and play if i ever need to upgrade
rest of the sensor are just common
tps
cts
mat
map
bosch wideband o2
