This build started in sept 2019, thought I was gonna be able to have it don't by my sons 6th birthday. That didn't happen due to some family passing away and then Covid hit. Finally finished it up this year.
I would also like to say this was my first fabrication/welding project. It's not perfect, but I think it turned out ok.
Anyway enough let's get down to the good stuff.
The kids chassis is from Goatbuilt, it was originally designed for a atv motor/trans. I had him make the subframe 4" deeper than the original design. It's a tight fit for the drivetrain I used but seems to be working so far.
Specs
Goatbuilt kids chassis
1.6 8v and 3spd out of a tracker on propane
Sammy tcase 4.9:1
Toyota axles 4.10s welded, cromoly shafts frt and rear, rear disc brake conversion.
Psc steering
37" sticky treps
17" pro comp steel wheel with total metal innovations weld on bead locks
Fox 14" frt and 16" rear air shocks
Prp rzr 170 seats, and prp 4 point harnesses
Rad designs th180 shifter
Wheelbase is around 100"
Weight is 2340
Specs
Sammy tcase 4.9:1
Psc steering
37" sticky treps
Weight is 2340
