1 Ton ZJ
Shifter install started.
http://www.pnwjeep.net/forum/viewtopic.php?t=6910&postdays=0&postorder=asc&start=300
How did ya secure the piece that went around the back side if the tcase? You don't think it will eventually slip off there over time do ya? Impressive thought and work you have done so far.
Let Dan know he is still a :looser:
Yes, Dan is still a Loser...:haha:
Thanks. The "Roark" piece actually clamps on to the rear output housing. I don't think it will go any where. Famous last words.
It moves :awesomework:
Whats the low ratio?
Previous set up.
1 gear 2.74, t-case 2.72, axle gears 4.56 = 33.94 to 1
With the Atlas
1st gear 2.74, t-case 2.72, axle gears 5.38 = 40.09 to 1
1st gear 2.74, t-case 3.8, axle gears 5.38 = 56.01 to 1
1st gear 2.74, t-case 10.34, axle gears 5.38 = 152.42 to 1
