1310 vs 1330
What is this fascination with power braking? I don't get it.....:eeek: This is why we have CUTTING BRAKES guys.
I have a completely dry front 1350 joint in my font driveline (at diff). It squeaks like a bitch and it's STILL holding strong.
What was the point of this thread again? :redneck:
I still run 1310's front and rear...they're like any other part on the rig, they hold up fine so long as they're maintained.
X2.
I've got 1310s all around with 160:1 gearing and never broken one due to torque. I've never tried to power brake in 2wd 1st low low though.
why not get bolt on yokes? harder to change the joints, but alot stronger....:stirpot:
:corn:
can you provide some proof that they are a lot stronger?
Sure they are--think about it..
No u-bolts or straps around the u-joint cap.
I run 1310's in the front and never had a problem. But I have very lil angle on the front joint. I run 1350's in the rear due to the steeper angle on the shaft.
Bigger joint for more strength--- You can't tell me a joint working at a greater angle is weaker than at a less of an angle?
Well I guess you can read that 2 way's. If you are trying to achieve dl travel, 1350 has the least movement of them all. If bind isn't the issue then of course your better off.
Oh no--bind is not an issue--well at least not in 4 years. But I agree you can read that both ways.
I find that funny--coming from you brad.
Why funny? they are superior to 1310s and 1350s.
Massive angle tolerance too. Remember boonies 1350 angle escapade.
I have yet to kill a toyota joint that still had grease in it.
I have a v8 in my wheeler and kept the toyotas tcase to make it easier to keep toy flanges in it.
Ever time they replace a toyota shaft on 4x4tv with a tom woods dana conversion shaft it pukes first thing out.
I have a $150+ CV on the bench right now that was a toyota to dana1310 conversion ( you know to get that strong spicer CV in your toyota!!).
Its from hiangle and is junk. torn apart by a beast of a 20r!!!!:beer:
1410 or toyota for me. Never could keep a 1310 or1350 joint in the stomper and it has absolutly NO angle on it.:beer:
Oh yeah, Mine was a tossup. It would either spit the ujoint or just split the GM yoke in half. No pattern to either.:booo:
WATCH THAT VIDEO OF THE STOMPER ON THE HOME PAGE, If you listen at the end you can hear a 1350 die right when the roost comes of the front tires!!
RIP 1350:booo:
Here ios why--you are a cheap person--you would go and spend $400 on flanges to run toy shafts :haha:
Seems better than buying shafts all the time.
Some **** is nessesary, cheap or not.
Any one with a drill can put a toy flanged yoke on chev tcase out put flange.
I even used some 1410 AG shaft flanges that were in the srcrap for the stomper.:awesomework:
Who are you talking to? I have not blown a joint.
SHow me and axample of there you just have to "drill" to make this combo work?
I am familure with a dana/toy flange--I had them on my 44.
If you want it perfect then you need to remachine a centering ring on both flanges. I just ground off one till it was flush on mine and matched up both flanges, tacked them together till done, and used a transfer punch to locate the new pattern. ground off the tacks and drilled itout and bolted it all together. I have used flanges from dodges, chevs, 205s 203s. any with the square flange. sometimes I have to swap seals to work with the new output flange.
The square domestic flanges as well as toy ones can be welded on too. if needed you could weld a 3/8 plate circle to it and drill as large a pattern needed! I have never needed to do that though.
As soon as I get some Bfast in my gut I will snap a few pics of some of my scrap parts.:beer:
i didnt wanna mention the T word, and get everyones panties in a bunch, and start a pissing match, but, since chopshop did...here we go:fawkdancesmiley:
theres a reason they make bolt-on flanges fo D60's, so u can run a toyota u-joint:awesomework:
a toyota joint/flange IS stronger than the d60 stuff.
0 Words
