B
Badride
Guest
Don't really matter. No matter what size, you have to turn the ends down to press into the center section.
TBItoy said:If it were me, I'd run 4".
Leave some stubs of stock tube in the junkyard housing, machine the 4" tube to a press fit over the stock tube stub...
Of course depending on what your stock tube size/thickness is...
if you do it this way you have designed a weak link in it but hey you are smarter than meTBItoy said:If it were me, I'd run 4".
traveler said:if you do it this way you have designed a weak link in it but hey you are smarter than me
traveler said:don't matter what you do on outside its only 1/4" on the inside
traveler said:your right I probably don't know anything about a 14 bolt
traveler said:I will take that as a **** you you don't need any help
Yea I'm running slotted drilled vented rotors I just made centers and transfered the patternparadisepwoffrd said:What are you doing for rotors? Redrilling them also or is there a slip over 8x6.5 the same dimensions? I'm guessing that you are running superduty calipers?
Or are you running something smaller/lighter?
ranger11 said:He's saying the "stubs" will be the weak link since they're 1/4"
The outside would be the tube going over the stub.
Why do you stalk me around the internet and call me out/talk down about any comment I make?traveler said:if you do it this way you have designed a weak link in it but hey you are smarter than me
