stroyer
Just got done with a prototype shroud to fit the Volvo fans for a friend. I will be running that with my 5.3. Real simple setup.
RustyC said:Bump for new info. I was able to check the actual current at my fan using a clamp on amp meter. I am running a two speed Volvo fan and a full shroud that can bee seen above. Radiator has 10 fins per inch. This is a junkyard fan with an unknow history.
Fan off and switched to low speed = 16.5 amps @ 13.5 vdc.
Fan off and switched to high speed = 67 amps @ 13.5 vdc.
Fan running at low speed the switched to high speed = 27 amps @ 13.5 vdc.
