Beerj
Sonzabitches!
Did he mention why you needed a slip other than to remove the shaft? Are you running rubber motor and trans mounts?zsavage81 said:planning to run a 6" slip so I can collapse the shaft, then pull it apart to get it in there. Drive shaft man says i need a slip between the case and bearing. I really wish I'd looked on the internet more and made the carrier bearing unit itself removable. Totally shitty design by me, gonna be straight screwed if the bearing craps out as those are pressed in.
