TacomaJD
I LIKE CHEAP STUFF.....
What springrates did you use for front?
X2 looks like you cut then off then built basically the same thing back? (Although inverted)tlspeed1 said:What the reason for ditching the bushings that are cast on the axle? I am doing an SAS on a 97 and I was planning on using them, just curious if you had any input. Looks great though.
EddieHall said:06 superduty dana 60 with the bushing cut off
well the 1st question is cause the mounting width i gained almost 2nd to get the 4link arm separation i needed.3rd so the frame brackets fit perfect under the frame rail and 2 these r rebuildable and flex betterTBItoy said:X2 looks like you cut then off then built basically the same thing back? (Although inverted)
im sure i could hav but i like coiloversparadisepwoffrd said:could you have used a coil spring from the newer chevy vs using a coilover?
it was 3 large metabo disc,and 3 4 1/2 smaller onesnatedawgxj said:WOW that must have been a pain in the ass!!!
make me a better one r find one that will clear the chunk ill buy itLightBnDr said:I feel like 5brothers when I look at that pitman arm....
I love the swap though. Sweet project. Love the pics
It's not so much about clearing the chunk as getting enough drop and still keep it safe! The best senario is change the angle of the box or do high steer for the drag link!EddieHall said:make me a better one r find one that will clear the chunk ill buy it
its the same one they use on the superduty they onlything different is the bore and the spline count no differenceal1tonyota said:It's not so much about clearing the chunk as getting enough drop and still keep it safe! The best senario is change the angle of the box or do high steer for the drag link!
You have measured the distance from pitman arm hole to tie rod hole on both?EddieHall said:its the same one they use on the superduty they onlything different is the bore and the spline count no difference
yep i used the superduty one to set it up and also i hav hydraulic assist with r&d i remembered. The xjal1tonyota said:You have measured the distance from pitman arm hole to tie rod hole on both?
and its not first one ive built 3 totalal1tonyota said:You have measured the distance from pitman arm hole to tie rod hole on both?
Aight cool I'm just looking at it from th internets and it looked sketchy you must have felt the same at some point to weld the braces on but to ya man!EddieHall said:and its not first one ive built 3 total
oh yea ive seen 1 a guy heated to get more angle and u no where im goinal1tonyota said:Aight cool I'm just looking at it from th internets and it looked sketchy you must have felt the same at some point to weld the braces on but to ya man!
