rpf500
The AW4 transmission was used in 4.0L equipped XJs from 1987 through 2001. It was also rarely used in 2.5L equipped XJs with the automatic transmission option, 1987-1990*. It has 3 regular forward gears and 1 overdrive gear, along with a torque converter containing a lockup clutch. Gear selection is part hydraulic and part electronically controlled via solenoid valves. Shift firmness is controlled by a throttle valve cable which meters fluid pressure into the valve body based on throttle position.
Gearshift positions -
Park - this one's obvious.
Reverse - obvious.
Neutral - also obvious
Drive - in this gearshift position, 1, 2, 3, or Overdrive may be electronically selected. See the table after this section for details. If the electronics are disconnected, this will put the transmission in overdrive.
3 - in this gearshift position, 1, 2, or 3 may be electronically selected. If the electronics are disconnected, this will put the transmission in 3rd.
1-2 - in this gearshift position, gears 1 and 2 are available via electronic control. The transmission hydraulics enable engine braking in 1st gear with the gearshift in this position. If the electronics are disconnected, this will put the transmission in 1st.
2nd gear is not available without some sort of electronics (stock, a toggle switch in the dash, whatever) powering the solenoids.
Is the part above about 2nd gear correct?
Reverse - obvious.
