Running ylink right now not opposed of full hydro I figured it was stronger. Do you have to be double triangulated to get away from track at?Front 4 link is a stronger design due to the additional upper link. It also does not suffer from the axle moving laterally because there is no track/panhard bar. 4 link does require full hydraulic steering though.
What type of steering do you have now?
My lowers are straight, but I can't get my uppers close to 40*. I was hoping to get rid of the trackbar.If you have straight lower links, I would not go below 40 degrees with the uppers.
If your lowers are triangulated to 45 degrees, then your uppers could be straight (no triangulation)
Think MINIMUM triangulation = the sum of the all the links of 40-40 degree total.
ThanksIf you have straight lower links, I would not go below 40 degrees with the uppers.
