clemsonjeep
Ill have to look around for my notes...hope i can find them.
MikeW74 said:Im no way by any means an expert or have a mass amount of knowledge on linking a rig,but i helped a friend link the rear of his rig about 2 months ago and one bit of advise that we took from a guy on here and on Pirate was we made the uppers 2 inches longer than the lowers and it did exactly what he said it would. It helped to point the diff up in droop travel and helped with the castor.
I plan on doing the same thing whenever i get the balls to cut the frame off. Wish i could give you more but im in the same boat. Still learning and still reading a ton of info on it.
clemsonjeep said:Yep...try not to get brainwashed by obtaining lots of flex or that air shocks dont work. Just spend some quality time researching link setups with air shocks that work. Looking at pictures and reading after thoughts is great. I bought my 2.0 Fox shocks from Down South Motorsports because they had the best price AND they included a free tune on them. In other words I told them what i was going to use them for and some details about my vehicle and they changed up the valving and oil level to better suit me. Could i tune them further...sure...but do they work great as is...yep.
If your rig is at or above the 4000lb mark id probably step up to 2.5 shocks though. Mine is sub 3000lbs.
Keeping links as close to parallel to the ground at ride height is very important...but not an absolute. Nothing is absolute...but everything has a give and take aspect. Just gotta figure out what gives you the most benefits that you want and stick with it.
^ true ****. Went RIDIN not to long ago with a guy that had some air shocks on a Sammy, piper may have pics of the rig.. Lemme tell u that Fawker was like a mountain goat. I did talk to him and he said it sucked until he put THA sway bar on, was very impressed with all the rigs that were with us...
