4 to 1 Gears
War-Jeeper
Mailbox Killing War-Ho
Hell Hole
Anybody know where to get them for a dana 18 twin stick transfer case? ive looked around a little bit but havent found anything
You're out of your mind if you blow that kind of money in a Dana18 :eek2:
BTW, Dana18's aren't twin-sticked. Just because they have two sticks doesn't mean jack. They CAN'T be twin-sticked.
How so? Mine has one stick for hi low and one for 2WD and 4WD
What would you suggest replacing the 18 with then?
Twin sticks means front only drive. Can your Dana18 do that?
Easiest would be a Dana 20. It will bolt right on, and is twin-stickable. You can even use the gears out of your Dana 18 (and one from a Bronco case) to make the LR ratio more bearable.
Better would be a Dana 300.
No matter what you replace it with, you'll need to toss that goofy offset rear axle and go with a centered one.
If it were me, on a limited budget, I'd get a T18 and put the Dana 18 behind it. You'll get a way better crawl ratio improvement with the granny gear than you will with a 3.15:1 gear set, the tranny will be essentially bullet proof, and you can still easily toss a Dana 20 on later.
I would just go out and get a new JK Rubicon with with it already in there just have to add the second stick.
And I dont think you can twin stick the 241 case
Thought they had a 231. 241 is diesel and 1-ton truck stuff....
Same story though... I don't think you can do a true twin-stick on them.... but they make a great base for a doubler :D
________
FETISH MOVIE
Whats a T18 are you talking transmission now? me and the numbers and letters on parts dont get along and i cant remember for the life of me what a T18 is
T18 is a heavy duty 4 speed transmission. Some have a nice 6.32:1 first gear.
The Rubicons have an NP241R in them.
transfer with 4.1 4:10x1 dana 44`s
:wtf: What the hell does that string of seemingly random p'unc!tu%at:ion mean?
Since when does twin stick mean the capability of front wheel drive only? Seems to me, twin stick means twin stick... front wheel drive only means front wheel drive only. :redneck: :flipoff:
We've sort of hijacked the term. In math class, I'm sure "twin-stick" is a generic term meaning "two sticks". However, on this here wheelin' board, "twin-stick" is short for "true twin-stick", which is the ability to make your transfer case do pretty much anything :flipoff:
Without the front drive capability, there really isn't any reason at all to even mention the number of sticks.
Twin-stick-without-front-wheel-drive-only (that's a mouthful!) does have a benefit, though. Rear wheel drive low range. Locked front and rear, tight switchback, need low and tighter steering... Rear wheel drive low...
True-twin-stick gives you that, too.
IMO there is no reason to run a case that can't do true-twin-stick. That rules our chains (:rb:) and offset rear output (:rb:) cases. There are plenty of cases available that offer true-twin-stick-ability. The only things those "other" cases are good for is pavement pounders and doublers. Oh, and paper weights :D
