4bt fj cruiser
slytowncrawler2 said:
Lowers are 36.5"
Uppers 24.5"
Separation at frame7.5"
At axle 15"
With this difference in separation between both do you have much anti squat? And does the pinion kick up?
The rear actually cycles real well... The pinion stays pretty steady throughout the suspensions range of motion...
I was expecting the rear to "walk" towards the front real bad under extreme droop but it's actually pretty good I can get u some pics if you'd like.
While I was setting this up I called a friend with a tj that used this kit. And even without knowing what his lengths were I ended up being very close to his setup.
His tj drives very very good with 43s so...... We will see
Thanks mike! What plans do you have for your yj??
the SYE showed up today from clayne (here), ive got some 4.5 leafs going spring over, ive got 79 ford 3/4 t axles... tires and wheels undetermined, im gonna see what i can get a deal on when everything else is ready. the rear 60 is took apart right now getting cleaned discs and diff. welded front will have a spartan. gonna keep the 2.5 until its clearly underpowered.
I have never run a ball joint style 60... I'm learning the cast center welds a lot shittier than most cast I have welded to. So I took some advise and bolted and welded to the center section ......
A friend has run a similar setup and could not get welds to stick ..... If this comes off it was ment to be.
The bolts are obviously too long Ryan is gone replace them tomar.
And before I done all that I made sure to weld tubes to the diff. Our friend also had trouble with twisting the tubes in the dif.
I don't know what it is about the cast on them housings, some lay a bead of weld great and others crack and break off right away....gotta be the casting carbon in them or something
Thanks Mike, Hope it works well for you.
I'm learning little by little how to make a tube bender do what I want. I'm almost obsessed with learning th art of bending tube. I still have a long way to go but I'm gettin there . The belly pan is one area where I learned a lot ......
Nut welded in the end of a tube. Bolts go through lower link mounts then thread into belly pan
Got the belly pan fitted nicely then it was time to skin it.
In this pic you can see us building a template for the removable skid that goes under the drive shaft.
Ought to make trail repairs easier
.25" plate. It's not that heavy I can lay under it and lift it into place while a friend installs bolts
