5.3 falls on its face
pholmann said:
I would agree that the new cam and lack of tune is the problem.
I ran my ls1 with a zo6 cam on my 5.3 tune around a little before I had it tuned, I wasn't doing WOT pulls or anything but it ran decent.
I know Travis Vance out a cam in his buggy and it fell on its face until he had it tuned. I think it depends on how much cam you put in. Also changes in things like intake centerline, lobe separation, etc
True, I'm just leaning towards the fact that you can't get too ridiculous with a cam on a stock 5.3. It definitely needs to be tuned.
Whats the story on this 5.3, was it running before? Is the tune stock?
216/220 114 cam
So I dropped by amigozone and picked up a few things
Fuel pressure gauge. ( 54 to 58 psi idel jump over 60 at wot)
Obd scanner and compression test tool
Before I started it today I scanned codes
Came back with
P0650 (lamp malfunction CEL)
P0122 (Throtle pos.sensor, could this possiably be tuned for dbw?)
P0500 (vss, why would it pull this code If it's tuned for mech. Trans?)
Cleared the codes out and drove it around the yard. Still not running right but a tad better.
Scanned codes again and p0650 came back in but not p0122 ?
Odd?
Fuel pressure looks good steady 54 psi. Disonnected 02 sensors and started to run worse.
I was able to read 02 readings and they were exactly the same, but not sure if this is what they should look like?
Here are some pics of logged info
Re: Re: 5.3 falls on its face
Motor was spose to be in running condition blah blah blah new cam amd springs blah. Pulled the pan off and looked like chit (look on my profile for thread and pics)
Short story long I rebuild this pos. And at lease it did have new springs and cam.
I know the motor won't run 100% with out tune but would it run this damn bad without it
Check out those fuel trims. The long term is high. What the hell is going on with your short terms. Those are way off base man.
Swapped TPS runs alot better. Idel is low but may be the cam? Still pretty sluggish driving.
I think you will continue to have problems until you get it tuned IMO it will save you a lot of trouble and time chasing problems a good tune will take 2-3 hrs to get it dialed in hope you get it worked out
And Im pretty much done taking educated guess , spoke with a local speed shop to just look into it. But a this point I just want it 100% ready to ride!
Got around to fooling with this thing tonight, completed a compression test (all cylinders test between 155-160 with three revolutions) leak down was 2-4 psi after 10 seconds) from a quick Google search these a good numbers. One thing I did notice was carbon buildup and 2 plugs had what seem to be gas. What should I be looking for on a fresh build?
I'm wondering if you have injector issues, in the short term trims you posted its adding a lot of fuel to one bank and pulling a lot from another???
That's what I was noticing. Also could have an O2 issue.
bjeep said:
Have you used them/him?
Vengeance is good real good prices too.. they are more of a high end shop. But their work reflects that. I'm currently speaking with moes speed shop in dallas ga, anybody was experiance with them
Re: Re: Re: 5.3 falls on its face
Would you mind breaking that down to me, as fast as what am I exactly looking at on scanner and so on
