WHITE TRASH1
fruit stripe
so the marlin springs have been sold. Looking to go with stock rears up front. Can I make the 51" rears in my truck end up matching? I've got some 3" lift packs, 2 sets of fronts and one set of rears, to play the mix and match game with. Looking at buiilding a drop/forward front spring hanger and move rear shackle hanger back to accomodate, along with 5" shackles front and rear.
Are t he benefits of moving the pivot point of the rear shackle above the frame worth the work involved? I've seen it done a couple times now, and it seems to make sense since you can use an ober long shackle to gain the benefits of the longer swing arc without throwing your departure angle to **** and keeping it low.
Sure you can mix and match and come up with something that works for you. I personally run my shackle in the rear up higher than stock by about 2" and I like it. not only does it allow for a longer shackle for travel reasons but if you keep the eye's of the spring pack close to level or even with the shackle end up a bit higher than the front you will get less effective anti squat and wrap.
