Cole said:SpeedSouth in Pelham
http://www.speedsouth.com/home
Also Joe had Hesco tune the Supercharged motor I sold him
http://www.hesco.us/
Yeah I remember Joe had a good experience with HESCO, I may try it out.
Also to add to this thread, beware that when swapping Car Intake to a truck it is not always a simple bolt on. I have an 06 motor, which has the good WP with the neck that is not in the way. But we tried to bolt down the intake and it was not even close to working. Idler puller and alt bracket would not clear the TB. Found a few brackets that address this, but unsure if I want to gamble on them and be out the money if they don't work. Also the truck intake bolts will not work on the car intake, so make sure your intake comes with bolts if you buy one.
Also I found the following links for Metric Adapters for Oil Press & Water Temp gauges. My gauges are mechanical, so these should work fine for me:
http://www.speedwaymotors.com/LS-Series-Oil-Pressure-Sender-Adapter,20928.html
Also if you are in the market for a custom made LS wiring harness, Pacific Fabrication has great service and reasonable price. My motor was a hack out from the yard, so they cut all the wiring. I ordered a new harness from PacFab that is a 4 wire hookup and includes a fan wiring for dual fans that is controlled by the ECM.
