84 gmc no name
jccarter1 said:
If I had to guess I would say the front is a GM 10 bolt/44 the rear is probably a GM 12 bolt :****: with 600 hp that is going to be one parts breaking mofo
Yeah I've got a 14 bolt lined up I'm Savin up to get it's hard as **** to find front 60s around me that aren't $500+
Odds are if you have 4low and nothing else, you have a shift linkage problem. Have you laid up under it yet and made sure you dont have a bent shift link or stick jammed in there. If all looks good with the shift linkage you might look into the possibility of a broken motor or trans mount keeping you from being able to get the transfer case into any other gear.
What exactly is your problem? Is the shifter stuck in 4low, or does the shifter move but the truck stays in 4low?
The stick moves I've looked under the truck and the linkage is moving but when you push the stick farward there isn't any gears it's like just shoving it in nutral
Well the old blue will be comin up for sale found a more interesting project trucks priced at $800 with no motor I don't think that's to steep
rednecklights said:
That pretty bad ass but my plans when I sell some **** is cj7 44front with detroit 60rear 4.88 gears 383 th400 208 on 39.5 tsl boggers
kmcminn said:
I don't think you have to worry about that.
SOB that mofo got some one liners... molaugh I'm Fukin dyin. Bahahaha
On another note, if Ya see more Dana 60 fronts, king pin, that are 600+, I agree that's nuts! PM me the number or contact and I'll call and let me know! :woot:
Look for someone who is selling a whole truck for that much and doesn't realize the value of the front axle
0 Words
