90's throw back....Manche build
Re: Re: Re: 90's throw back....Manche build
rebel taco 22 said:
How does it do at speed? Had it up to 70-80 mph yet?
Do you think you could use it as a hardcore expedition vehicle?
I've been going back and forth about having a mechanical link and saw Goatbuilt's subframe for a 3-link.
Haven't been to 80 yet. Still need a true alignment for toe in adjustment.
Steering wise, it is a slight bit twitchy on road at <2.5 turns lock to lock, but that is likely due to the toe in currently. (5.5 ° caster at ride height).
If I wanted it to be more highway speed friendly I would either put in an overdrive trans (which I am kicking around doing already) or raise the gearing to about 4.88-5.13- don't want to do. It's right on its power sweet spot at speed on 37's (3000rpm @ 60 mph) with lots of room for acceleration up too peak hp, so I really don't want to change the overall 1:1 gearing. A double underdrive 6l80 would be the cats meow right now. 42's would help even more than my 39" krtb's, but I didn't build room for them nor do I want them.
I certainly wouldn't be afraid to run it as is in an ultimate adventure scenario (and adding bed storage rack).
Had a little shop time today. Got the hood vents fabbed and installed.
I raised the profile of the screen to give it some depth, and to clear the vent on the steering reservoir... it just kissed the hood before the cutouts.
Matt
The raised mesh looks very good.. :dblthumb: Matching pieces on the cowl under the wiper arms would be flashemifyougotem.
Looks awesome. I have to ask, are all the rivets functional to attach to the hood? Lol.
Just was curious if only a few go through the hood and panel, or all.
That's a good idea....hmm
All or nothing baby..., but the hood lost no strength once all buttoned up, lol.
For sale! Gotta strike while the iron is hot...
1990 (NC) street legal jeep Comanche MJ.
About 50 miles since built and climbing. It will still be driven, wheeled, modified, and tested on, until it sells. Serious buyer can request more fabrication and modification with hefty deposit and secure confirmation of full payment upon completion. Delivery assistance can be arranged for long distance sell...ex- Could possibly be delivered to KOH or Easter jeep.
Current Specs:
-06 corvette aluminum ls2, less than 30k miles; Mast motorsports db90 computer and harness, estimated 450+ crank hp. Stainless eBay turbo headers, 3" exhaust, Bomber fabrication alternator bracket with new 140 amp unit, f body beltline with -16 AN water pump, new Flex-a-Lite 27x19 radiator with 3000 cfm fan, Psc N- pump and filtered reservoir, 3qt Moroso accumulator. Custom length wires and relocated coils. I have the link components to hook the mast computer to a laptop as well.
-th350 trans built locally. Refreshed in newer case during build. Art Carr RMVB with compression braking, lower first gear, extra frictions. Plus 2 qt aluminum finned pan, Derale cooler and fan. 24-2600 stall 10" converter. Winter's shifter with modified gate
-Atlas 2 tcase. 3.0 drivers drop. 1350 yoke. Cable shifter.
-4 brand new Tom Woods driveshaft. All 1350, 1.5" spline slips, 2.125 x .188 Dom. Two piece front with carrier bearing. Universal long slip spare for front and rear.
- AXLES; used Spidertrax axles front and rear, 3.5"
-Front; ultimate 60 knuckles with new uniballs, new spidertrax unit bearings, 6x5.5, spidertrax 14" rotors and hats, new wilwood 4 piston calipers, new Yukon hardcore locking hubs and new spidertrax drive flanges, CTM 300m 35 spline axleshafts, CTM ujoints (1 new, 1 used), Goatbuilt steering ram mount with new PSC dual ram and new 7/8 heims. My own fabricated front truss system with inner C supports and bash plating. Mega hi-9 drop out, 5.40 gears, 35 spline pinion, spool, forged yoke, dual load bolts, bronze pinion support, fresh Red line heavy shock lube. 66" wms.
-Rear; used spidertrax 3.5" housing. Used spidertrax bearings, new 14" rotors, hats and 4 piston calipers. New 5.43 gears, low pinion, spool, CTM 35 spline 300m shafts, new spidertrax flanges, stout truss, new bash plating, new upper link mounts, new Barnes pinion guard. Fresh Red line heavy shock proof lube. Forged yoke.
- CHASSIS
- my own chassis design. Mix of 2"x .120, 1.75"x .188, .120, .090, and 1.5"x .120.
-Goatbuilt subframe, boatside tubing, rub rails, engine cradle, all skid plating is Goatbuilt .120 Domex. Skids can be dropped without disturbing engine and trans mounting. Bare steel, oil preservative.
- my own bumper systems with tow points, and hidden winch mount.
- many sheets of custom beadrolled aluminum and steel panels, designed for protection when running without factory jeep sheet metal.
- dual triangulated four link front and rear
-SUSPENSION- excellent go fast geometry, can provide calculator numbers at request.
-FRONT; equal length dual triangulated. 2"x 250 steel links, new 1.25" Barnes heims. New 16"x 2.5" Fox factory series coilovers with DSC adjusters. Pac racing springs, 16x 150lb over 18x 150 lb. Shocks mounted 1:1 on axles. New Wide Open Designs limit straps. 16" wheel travel unstrapped. Heavy compression damping valving installed by me.
-REAR; trailing arm long arm. 1.75"x.120 dom upper links. New 14"x 2.5" Fox factory series coilovers with DSC adjusters. Eibach and King springs, 225 over 250. Custom shim stack installed. WOD limit straps. 21"travel unstrapped.
-Trailing arms by me.
- Currie .750 swaybar with modified arms on trailing arm.
- ELECTRICAL, Plumbing, safety
-kwikwire 14 circuit harness. Fan powered through computer with manual override. New Glowshift gauges, heavy toggle switches, road legal lighting (mostly Maximma brand) , 20"led front bar, 6"led rear bar, rock lights, led interior and mood.
- Front and rear circuit, brake line locks.
- all plumbing is stainless and nickel/ copper hard line, with Jegs 3000 series pro line and fittings.
-Goatbuilt 18 gallon fuel cell, factory style in tank pump- walbro 255, corvette filter/ regulator, 100 micron down steam filter housing. Fast fill fender plate. Stainless hard line vent, 3 sides and down.
-5lb fire suppression system, 5lb ABC and 2.5lb ABC hand held extinguishers mounted inside and out on TMR quick release.
- used Twisted Stitch seats with removable bottom pad, new Prp 5.3 harnesses with padding and sternum strap.
- new Rugged Radios 660 intercom and 50 watt radio. Uninstalled and in need of wiring and headsets.
-Smittybuilt 10k winch with new rope.
- new optima yellow top
-BRAKES
- All new Wilwood; dual reverse swing master cylinders 3/4 bore, forged pedal, 4 piston calipers and new pads.
- TIRES AND WHEELS, 2 mounted sets
-9 pro comp wheels, 17x9, -6 offset
-4 used mounted Nitto trail grapplers, 37", +80%.
-5 used mounted BFG KRTBS, raced once, 39", +80%. 1 is 95% (mounted spare).
-1 new bfg krtbs 39", zero miles.
- SPARE PARTS
- new water pump, used alternator (2), new PSC N- pump, CTM outer stub axle, fluids, low pinion Currie 9+ dropout with new 5.43 gears and forged yoke but inoperable Yukon locker, front link with heims, steering heims in front push bar, driveshaft, spidertrax drive flanges. Multiple doors, fenders, front early and/ or late header panel and bedside possible.
- MENTION WORTHY
- new windshield, operable wipers and washer fluid.
- All turn signals work, along with stock headlights and high beams, factory horn.
-water tight tool box with room for fluids and tools
- mounted full size spare tire
- functional tailgate, hood release.
- removable door mod, with opening door tube. Factory mirrors
- flex-a-lite Mojave heater.
- factory rear sliding glass
-Joe's racing rear view mirror
- steering wheel quick release
-cupholders
More to be added, and I'm sure there are nuances some folks remember through the build that makes this truck one of a kind. This has been the most fun of anything I have built in the last 20 years, and I'm looking forward to concentrating on building more projects very soon. It wheels as suspected, and hauls ass in its current form. It could be raced if desired, with the deletion of panels and glass to get under weight, and the addition of required safety gear.
Because there has to be a price...$80,000, as listed, with option for delivery. This deal could be made for less and is negotiable with changes to some of the above listing. Customization after deposit made, may change final price. Not interested in selling as a roller, not interested in trades at this point. Cash talks...
Located in NC, 27030.
Contact info;
Matt Cutler, 336.401.2830
Build threads here...
https://www.nc4x4.com/index.php?threads/170413/
http://www.pirate4x4.com/forum/showthread.php?t=2261513
http://www.hardlinecrawlers.com/forums/index.php?topic=50078.0
http://www.dezertrangers.com/vb/showthread.php?t=231912
Walk around videos can be seen on busted knuckle and madram11
I'm grateful for all the praise from my peers in all the build threads, its humbling to say the least. I look forward to starting the next one and continuing to share build together...
Sent from my SM-G925R4 using Tapatalk
noracin said:
But why ?????? ???
this ain't no museum, everything is always for sale... just making sure folks know that...
tonybolton said:
Because that's what build threads are for.
Lol. Guess so.
There will be another build thread soon...
Well hell. This will sell a lot quicker with a burn out video. Just saying.
mcutler said:
this ain't no museum, everything is always for sale... just making sure folks know that... Lol. Guess so.
I wise man once told me the exact words! " this aint no museum, everything is forsale!" :****:
Snow day, shop day...
Running the exhaust to the bumper, try to get a few decibels down in the cab. If this doesn't help, I'll be changing mufflers from the delta single chamber to something else.
Matt
Matt
REALLY? What the hell are you thinking here? A silver coil above a blue coil on a red truck? SHEEESSHHH. RobbyBobby wouldn't even have that. Kick your seeing eye dog and get it right. The Blue coil looks way better over the silver and put some rattle can on that thing. :rolf:
ADMINISTRATOR
onepieceatatime said:
What's a Comanche without glasspacks?
It almost sounds like glass packs are run through the b post.... lol, I'm too old for that ****.
ADMINISTRATOR
It's the Merica theme color coordination...????
Matt
I really like these vents can you go into more detail on how you fabbed them and what the materials you used ?
The surround is .063 aluminum. Just made a template, the stainless screen dimension was determined by how much screen I had left, lol. Ran the frame through the beadroller, both interior and exterior of the opening. Traced the opening onto the screen, and then ran it through the roller as well. I then cut the hood out about 1/4 larger than the interior of the frame opening. I sandwiched the hood between the frame and the screen. Riveted 3/16 with back up washers on the screen. Then I massaged the raised area of the screen with some body and dead blow hammers, to get a higher, more uniform bulge. This woven screen doesn't beadroll very accurately because it tends to squirm around due to the weave. I'll likely make a frame for the inside at some point as well, so it would hide the edge of the screen inside.
... round 2... 1st version wasn't enough tire clearance during articulation...
Kinda got that trophy truck exposed exhaust thing going on.
Made quite the difference, sitting in the shop anyway. Roughly 70" of tube was added from original. It did eliminate the rear firewall rattle when I run the rpms up.
I have also scavenged an 8" resonator from 2008 powerstroke exhaust that makes it even better even placed just behind the tire, if I decide this isn't enough.
Matt
