crash2
-Oh no I picked a side-
I am going to suprise my son with an early x-mass present. I started it yesterday.
Day 1
Pulled both axles apart, cleaned and inspected. Lubed and assembled to make sure I broke nothing,lol.. Had to cut the pinion off one motor and replace it. Installed both motors (HH 35 turn) with 12/13 pinions and wired and made shields.
Made the chassis and links..
Day 2
I got the rod ends adjusted correctly. One thing with how the links are bent and how wide the housings are I have found you need to have the rod end sitting just right. I got the shocks cleaned and setup for around 3.80" of belly clearance. I want to get a set of shocks like I am running here soon. I got the coss supports done(out of delrin) and the rear lipo mount on the rear housing. I also threw his wheels on. Unfortunately he will be bummed about his wheels because they won't work due to the deep offset so I will throw on a set of RC4WD's that I have off my rig.
Day 1
Day 2
