A slight rebuild
Shock mounts are done, sheet metal trimmed to fit, just a little fine tuning on the tins to do.
Springs are incoming
matt
mcutler said:
Thanks tfrot
Front sheet metal is 2009 dodge charger, chassis is Jim's Garage #7
sorry I didn't get the chance to stop by. ended up going a different on the way home. hopefully we'll see ya on the trails 8)
Sounds great buddy, we typically do harlan in July, Dixie run Sept and harlan again November. A few more speckled in between.
matt
Sometimes when we make changes you get that snow ball effect ya know. ...teaser
More to come
matt
Finished the tube work on the new fender openings today. Still needs trimming out around the headlight but getting close. Got the tube bent up for drivers side as well.
matt
Just the fender tops. I had intended to use as originally mounted but due to the extra 2.5" of up travel i achieved with the new truss i had to trim so much from the opening that i really didn't like how it turned out. The tire was also getting into the market light on the ends of headlight at full lock/twist. So it got nixed as well. Going to do something a little different on front fender sides.
matt
Have the passenger side done and every thing cut and ready to go together for drivers side. Almost ready for new skins on sides, cleanup and fresh coat of paint. With a change in color scheme on the tins.
matt
