Alternator bracket for Chev 350?
got a quote from Napa today.. $131... ughhhh for the long water pump.
... however, I think that will be the route I'll go. There just seems to be more options for the LWP
Wow!!! $131??? Let me do some checkin':;.....
Wow, that sure isn't much belt wrap around the P/S pump pulley...how's it work Dobber??? (No squeal?)... I like the 2-belt system w/ long long water pump better myself (if you've got the room).
doesnt have any squeels, drove it out in the street and up on a few tires thats about it since i put the trail-gear kit on. Ive had my toyota pump in the same location for a few years now and it has never squeeled.
Fawk, I dont even charge that much to build a custom bracket for a pupm or alt.
I just did two samis with custom toyota pumps on a sami motor for 100 each and that was with an idler and over a halfa wrap on the pulley.:D
That was what he was quoted for the water pump...not a bracket genius!!!:haha: He got a pump cheaper...
I understand the quote was for a long pump. He said it in black and white. What I was saying is that I could have built a bracket for less than the DIFFERENT pump.
A new pump and new brackets and pulleys are alot more than a hundred dollar bracket that leaves all the old (short pump) alone.
do the math, genius:fawkdancesmiley::haha:
man where'd you find the ps pump bracket? a buddies been lookin for one for awhile. but hey i have a alternator bracket off my chevy 350. not sure how much to ask for one but its in yakima. let me know man
I went over to his place tonight, and he's got some work ahead of him...once he gets his springs in, he's gonna tackle the pump/alt/ps setups....may end up over at my place if he can't get it together....:awesomework:
Good, take care of em. Make it work!:clappy:
yah, this is a real pain in the ass. I'm hoping the long water pump will work, and line up the alternator bracket.
I'm just hoping that with the extra work tonight, that I can get everything done tomorrow for Rieter saturday! .. (heh fat chance)
Not sure want your look'n for. You need the alt mounts of the ps mounts. All 6 of my gm motors have the alt on pass side and ps on driver side. My ps has 2 belts on it and and a serp to my alt. If you haven't found the hardware let me know. I might have it.
If you are trying to put a long water pump on a v8 yota it's gonna be a super tight squeez unless the radiator is moved into the core support, the engine is moved into the firewall or the radiator is in the bed... When I did it I moved the radiator. :D
As for the single belt running everything that is a bad design... The limited amount of belt contact will let the belt slip under hard usage. The aluminum pulley will get hot and slide right off of the pump... I had that happen to a buddy with a slightly loose belt on a yota application so it had at least double the belt contact...
There's room---measured it last night....the Original fan is being omitted in favor of a 16" Electric pusher.... Maybe the Rad has been moved? There's an inch or better with a long pump in there...Just need to get the right pulley setups for the crank & w/p which I think I've got...:awesomework:
I'll get pics when I can find my cord uploader thingy..
anywho, it looks like I found a solution!
1) fab up a ghetto bracket for the PS pump
2) purchase a long water pump... the short water pumps will only work if you have headers
3) with the LWP, you can get a bracket that puts alternator on the passenger side, but on TBIs the old style bracket that goes to the intake bolt won't work because a sensor is in the way :mad: :mad:
So yah, I'd have her running, but unfortunately the RTV on the water pump apparently didn't hold. I filled her up with Coolant and drip drip drip she went :-( I'll have to take it apart, clean, it and try to reseal then. Oh and it looks like a new bottom coolant hose to the radiator will be in order (the SWP host is too long for the LWP so it doesn't seat right, causing leaks)
alt brkt
if your in redmond you can stop by my place and copy my templates super easy to build......fits swp. bring sum beer!!!
