Sold/Expired Aluminum Performance LS Oil Pans
Hired Gun Offroad Aluminum Performance LS Oil Pans are hand crafted in America, we are confident that our pans are the best on the market. HGO oil pans have a baffling system that is designed to provide oil while at an extreme angle. Our pans stand out with the following characteristics:
*Assembled on a fixture to maintain perfect tolerance
*.080" Thick Shell
*3/8" Thick Gasket Rails
*100% Tig Welded Inside and Out
*Billet Oil Port Block or Oil Filter Pad
*7/8" Diameter Steel Oil Pick-Up Tube
*Baffling and Windage Tray for Racing and Extreme Angles.
*Every Pan is Custom Crafted
*Each Pan is Pressure Tested Before We Send it out the Door
*5 Quart Sump
*5 1/8 Maximum Height
*Guaranteed Satisfaction
With side or down discharge to remote oil filter-$789 Shipped in the lower 48
With Oil Filter Pad-$969 Shipped in the lower 48
Anything is possible so if you need a special design or want one built for an engine we are not offering please let us know. Because each pan is individually built we can add any number of options.
