AN fitting question
I suppose I could also go from a -6 AN to a npt thread and then a npt, then to an elbo and then to a 3/4 flaire fitting..
Hi-jack
sick_boy said:
you could also make a trip to renton to honest performance and pick up any AN fitting you need, but the one in federal way has the biggest selection in the state of AN fittings
Honest performance in renton??? Where did they move to? Last i saw they closed shop, I showed up the day after they closed.
NPT is the devil. You're better off with compression.......
CrustyJeep said:
Well, it's the devil in an application where you need to couple/decouple often...
Well--thats why you learn to do it right the first time :flipoff:
Binder said:
Also do yourself a favor and stay away from that aluminum crap.
So stainless only fittings? I guess i need to research this quickly
crash said:
They also have steel versions joe...
So i should get all steel then huh?? I'm having a hard time understanding why alum fittings arnt good enuf..fwiw ive never had em on anything.
The steel ones are stronger is all. I went over to the hydro place yesterday and they have alot of JIC stuff joe(place on the other side of 405 from your work)...
Get what you need? What you end up doing?
AN is aircraft stuff (Army/Navy aircraft stuff). Overpriced with no benefit for offroading IMO.
Ya they did. I just got a -6 to 3/8 npt and then a fitting to a 3/8 inverted flare to run hardline down close to the frame rale then a short section of rubber to the frame and hardline back to the tank...
I go there twice a week...This week will be redemption as my lines will be done.
