London Gentleman
Here is the engine bay, gotta wire it up and let it purrrrr! :stirpot: Boonie built the hoops for me and welded them on, I think it was thunder and lightening out while he was doing it!
If I lift up the trans and case up to make it a flat belly, do I need to pay attention to the angle of tilt on the motor(front to back)?
What thickness of plate are you guys running for a flat belly? 1/8th or 1/4 inch?
I gotta check my angles but I got a longbed 1st gen so I have more room then a normal 1st gen, but then I got duals and a W56 so now im about normal, I dont have that much lift so that will help.
The structure the skid plate will be bolted to will be some sort of square tube bolted to the frame so it'll be fairly strong structure. Maybe I could get away with 3/16 but Ill check what the price difference for a 4'x8' piece between the two and go from there.
