Annual Hangover run---Tonga
Trying to get the jeep done in time for this. Haven't had a chance to play in the snow with the 42's or the new engine. Could be really interesting.
Not sure who got the trophey last year but the year b4 Morgan (not sure if he is on the board) got it.
Think I might have to do alittle maintence to my rig and go.
I think morgan has it--not sure. I might swing by and find out.
if not then its time to start a new NWW version :awesomework:
Wait---you getting permision to go play :fawkdancesmiley:
Think we should just start a NWW version. Yep got permission just like you:fawkdancesmiley:
I'm running an 85 4runner with new 32x11.50 bfg km2's, locker in the rear - open front. Would I have any problems on this snow run? Where does everybody meet up at and what time?
How do you not have 220 at your parents? All homes should have it.... Don't know of one without. You just need an extention cord made to use it.
Different plug and my mom would kill me:redneck: would have to run through the whole house and move the dryer to do it. No room on the panel to wire in a new plug either
Welded it up today, but found that my pinion bearing is toast (rather beyond it actually) So im out for this gotta pay for christmas gifts first so no money to fix the rig for a little while:booo:
sam if really want a new 220 plug at your parents house i can heip you make room.
Someday maybe i got the welding done i needed too for now:awesomework:
If the panel is totally full though how would i even go about it?
there is ways to do it but can't tell you for sure intill i seen a picture of the panel and the type of breakers it already has in it.
some time take a picture of the breakers and i can tell you if it can be done.there are this breakers called peanut breakers that can be used.
I'll save my passenger seat if you want.:awesomework:
Maybe a good co-pilot can keep me from "pluggin":redneck:
Didn't get bad enough to destroy the ring/pinion did it?:eeek:
will do! When i go by there tomorrow i will try and remember too
You know that rattling noise in the front end at high speeds?
Well if you remember what im talkin about it was the pinion bearing the whole time:mad: and im not sure about the ring and pinion yet i dont have the motivation to pull the cover and find out to be honest. I will also have to roll the axle up a bit to make it so this doesnt happen again probably have to cut the inner C's off and rotate them so it works properly:booo:
I could load the yota up on the deck of the Ford
And you still might have to back down a ways.
Just try to get up there before the "granola munchers", get turned around before offloading and you will be fine.
I usually get up there REALLY EARLY to do just that. Yet I still get blocked in by a F***ing Subaru!
I am going to block you in too :fawkdancesmiley:
