TN-CTD
I built a cooler once with some 6x9's and 5.25's. Used some head unit with a lawnmower battery. It was really good for tailgating
Lurker said:Normally id never post.....but this thread is win. Don't use plywood unless you plan on using a higher plycount birch. Al would sound like a tin can full of rocks. Best bet would be to use mdf in the 3/4 variety. Talk with your local lumberyard about the exterior grade mdf, it tends to deal with moisture a bit better then the other.also keep the sub/speakers in a separate chamber or you will run into some cancellation. Proper airspace for the 12s i think i saw mentioned earlier would be bout 1-1.5 cu feet each, 6xwhatevers will live fine in something big enough for them to fit in.
For those who skipped the lurker tech...I'm in before this thread goes south, since OP is gonna do what he wants
Sent from my Event using Tapatalk
Silverado.on.rockstars said:Alright sweet. What do u mean by crossover? Could I do a piece of wood cross ways to seperate air space
