Beerj
Sonzabitches!
I guess now you don't have to be rigless next week.
Just for the record, the starter button was in perfect working condition, when Kel stole my buggyBUG-E J said:Ha! I didn't know if you wanted me to let the secret out
Mine is wired on the hot side of the fuel pump/pcm power relay.ridered3 said:Question about kill switches both hidden and in plain sight.
Do you wire the switch to the Negative side or Positive side?
Yes and one will also run on the alternator so make sure you kill the fuel and spark.customcj7 said:I always kill the power, depending on the item, many times they can "find" a good ground through the body or frame via connections and bolts.
