MtnGoat
B.DRAKE said:Good lookin Toyotas man! Post more pics and specs of both! I too love me some Toyotas I have had the one in my avatar pic for about 16 years
Thanks boss... I will get some more pictures up soon.. The 4-runner pictures are somewhat outdated. Dad has added a winch and led light bar which really set it off. The inside of the 4-runner is crazy nice compared to my junk.
The light gray truck I build last year..5.29s, lockers, 38s, SAS with 5in springs, bobbed bed...blah blah. I loved the truck but just wanted a 85 ext cab with 40s...so that's what I put together.
<Vehicle>
1985 Toyota Ext. Cab
4cyl. 22R Engine
<Under The Hood Modifications>
Re-Build 22R Engine (Rings, Gaskets, etc.)
Trail Gear Rock Assault Power Steering Kit w/Cooler
Got Propane "Propane Conversion Kit"
<Drive-train Modifications>
Trail Gear High Steer Crossover Steering Kit
Steering Stabilizer
Custom Machined (5) Bolt Steering Knuckles
Trial Gear "Trial Safe Axle Seals"
Rock Ring Extended Button Head Bolt Kit
Complete Knuckle Rebuild (Seal, Bearings, Hardware)
FJ80 Tie Rod Ends
Custom Toyota Axle Truss
Front/Rear Differential Armor
Trail Gear Magnetic Drain Plugs
Longfield 30 Spline Heavy Duty Axles 4340 Chromoly
5.29 Ring & Pinion (Front/Rear) (Complete Re-Build)
Detroit Locker (Front/Rear)
Longfield 4340 Chromoly Hub Gears
Differential Breather (Front/Rear) Under Hood Flex Line
1.5" front wheels spacer
1.5" rear wheels spacer
Toyota Trail Creeper 2.28 x 4.7 Dual Transfer Cases
Twin Sticks
Dual Transfer Case Cross-member *Budbuilt
Tripe Drilled Input Flange
Triple Drill Output Flange
.250 Wall DOM Front Driveshaft w/ Spicer U-Joints (Single Flange)
(2) Piece Rear Driveshaft .250 Wall DOM w/ update new center support bearing
FJ80 Master Cylinder High Volume 1" Bore
Electric Rear Brake Lock (Emergency Brake)
Bomb Proof Motor Mounts
Bomb Proof Transfer Case Mounts
<Suspension>
All Pro Front Spring Hanger (+1.5" Forward Axle)
6" All Pro Leaf Springs Front
6" All Pro Leaf Springs Rear
Trail Gear 5" Greesable Shackles
Upgraded U-Bolt Plates and Bolts
Performance accessory 3" body lift
14" Bilstein 5125 Shocks (Front)
14" Bilstein 5125 Shocks (Rear)
Custom Front Shock Hoop (1.5" .120 Wall DOM)
Custom Rear Shock Hoop (1.5" .120 Wall DOM) 37Degree Mount
<Protection>
1.75" DOM Custom Built Rock Sliders
1.5" DOM Custom Front Bumper w/ Custom Billet Aluminum End Caps
1.5" DOM Custom Rear Bed (8-Bolt Removal) Grade 8 Hardware
1.5" DOM Custom Tube Doors (Not Shown In Picture Below)
Custom .250 Plate On Frame Rails In Weak Points
<Tires/Wheels>
15" MRW 18 Bolt Grade 8 BeadLocks (Custom PowderCoated Red Ring/Gloss Black Wheel)
16-40 LTB Super Swampers
<Recovery>
Recon 10.5lb Winch *50' Syn. Rope *Wireless Remote
46" High Lift Jack
<Lighting>
Custom Front/Rear LED Under-Glow Lights
36" LED Light Bar (Custom Roof Mounts)
Custom LED Reverse Light
LED Tail Lights
LED Corner Marker Bulbs
Tag Light
<Appearance>
Custom Metallic Gray Paint (just to save the truck for many more years)
Diamond Plate Custom Side Panels
Custom Propane Tank Straps (2-Tanks Located In Bed)
Flex Fender Molding (Front)
<Interior Modifications>
Custom In Dash Oil Pressure Gauge
Custom In Dash Volt Meter Gauge
Auto-Meter Tachometer
Sony Explode CD Player With Aux Output
Sony Explode 8" Speakers (2x)
Custom Buck Seats (Black) Dodge Neon
Lap Belts
Fire Extinguisher
<Storage>
36" Diamond Plate Tool Box
Igloo (My $20.00 Yeti)
<Communication>
Galaxy 44 (Hi/Lo Output CB)
108" Antenna Whip
Barrel Antenna Spring
Custom Antenna Whip Holder (To Pull In Shop)
Custom Rubber Radio Antenna (Prevent Trail Damage)
