Anyone run this winch?
617_Racing said:
I'm running that exact winch. Only issue I have had is the wireless feature no longer works, it just clicks a solenoid.
But, with it plugged in it works great, it has never let me down.
Nothing to do with smittybuilt winches but, I hate the wireless winch feature, I bought one for my HF winch and the thing would just turn on by itself sometimes. Not sure if a garage door opener triggered it or what, good way too get a finger pinched or have something tear up on the rig. I kept it unplugged after that unless it was being used.
On the Smittybuilt you have to hit a button on the solenoid pack and click a button on the controller to activate the wireless. When it worked it was awesome, didn't have to fumble with the wire at all. I would only turn on the wireless switch on the solenoid when I needed it.
tonybolton said:
I run the first gen 8000 version of this. Its fast...unspools great and works everytime I need it.
The only issues I've had are the engage/disengage lever. Its become "notchy" and you gotta fiddle with it sometimes for a few seconds and/or knock the lever engaged with a tap of a rock or palm of your hand. Its no bother really.
When you use it as much as you do, I can understand. ;)
Seriously though, it does work good. And after my last flop, looks like I'm gonna be getting one for mine.
Re: Re:
tonybolton said:
Its way overkill....but sometimes ya gotta help a 3 wheeled Rockwell rig up a steep hill. 8)
Keep in mind this is only an 8,000lb version. I've "double pulled" with an 8274 and had to wait on it a few times to catch up. :D
Completely offtopic, but have you had any problems with your suckdown set up? It looks like it runs to the axle at a pretty good angle, mine is about the same angle and I hadn't seen any running at that much angle.
Re: Re:
Used to be my old rig and it always worked fine for me other than it rubbing the front bumper which is why there is a piece of delrin bolted to it
Jesse's right....it did work for the near year I ran it that way. I've changed the bumper up a tad since then.
Was going to run the cable behind the bumper but never cut the new hole for it.
The last few months I had it like Jesse has it...I noticed a few strands broken in the cable. I run a synthetic rope now.
I mostly just trail ride crawl around on stuff....so honestly I never really needed to pull the front down to actually need it.
Re: Re:
I'm a firm believer in ya buy a winch for other people....not yourself. ;)
Hopefully I can keep true with that in 2016 as well. :)
