How about a TH400 that was used with the Quadratrac? It had the same Texas bolt pattern that the D20 t-case used and it should be easy to find. This is probably your least expensive option.
Stretch will be req'd to make a decent d-shaft. The 20 will be a better option than the 205 and if he decides to wheel it later a 3.15 low gear kit is available.
