jeepmauler
- Joined
- Oct 17, 2006
- Messages
- 2,064
- Reaction score
- 0
...........aparently.
Yer an ass. :flipoff: :kissmyass:Jobless said:That'll never work unless you 1st sand blast the housing and then use etching primer...what are ya...new![]()
skrause said:Yer an ass. :flipoff: :kissmyass:
O.K., we are going to see how good this stuff is. I just painted the coils I pulled to put new airbags in with the can you left me a year or so ago. Stuff goes on thick I will say that. Doesn't look like it will be dry until tommorow even in the heated garage.skinny_pedal said:best rattle can ever comes from tacoma screw. MRO is the name....the tacoma screw brand is also relabeled MRO. it literally is the bomb digityeverything else is just pitty poop:redneck:
notstock said:O.K., we are going to see how good this stuff is. I just painted the coils I pulled to put new airbags in with the can you left me a year or so ago. Stuff goes on thick I will say that. Doesn't look like it will be dry until tommorow even in the heated garage.
This the stuff you guys are talking aboot? :corn:notstock said:Stuff goes on so thick it looks like powder coating after 2 coats. There is overspray everywhere in the garage, it turns into a fog when you spray it. Not dry yet so they are sitting on the woodstove baking right now.
I bet the house smells just lovely :redneck: :redneck:notstock said:Not dry yet so they are sitting on the woodstove baking right now.
I have the front door wide open, a little warm outside for the woodstove anyway. Fumes were getting to me.:dumbass:CrustyJeep said:I bet the house smells just lovely :redneck: :redneck:
Kinda like Hammerite in the oven, Mary loves when I do that :redneck: :redneck: :redneck:
Uh, ya, enamel has always taken longer to cure. Duh. :flipoff:TTF Fabrication said:it pretty much is powder coat in a can.. it takes much longer to cure than normal spray paint. but if you are worried about quality, it doesnt happen fast.
skrause said:This the stuff you guys are talking aboot? :corn:
http://www.farmhardware.com/SuperStore/SuperStore-Product.asp?ProductID=8263
KarlVP said:If you want housings blasted, I can get them done. (You should be able to also, on the base hobby shop.)
If that isn't an option, just clean (wire brush, sand in the nasty spots) clean, (Prepsall, brake parts cleaner or other solvent), prime (el cheap-o primer from autozone, home depot or whatever) then paint (duh)
This method is tried and true, been working for years.
