Back to square one.......
Be careful what you type, lest you end up with unexpected repairs.
Thats going to happen no matter what and it happens to everyone so no worry's on my part. I have been "that guy" before and will be again. Its all just part of the fun
couple of more pictures, including spidertrax 4340 shafts and Bobby Long 300M Joints
The rear shocks also ended up in the tire when fully flexed, i cut off the old shock mounts, and made new ones, clears fine now.
Mounted Sway bar tabs.
Also included is a picture of the clearance for the front shaft. I have a couple tricks to get more room, but wound't mind hearing some more opinions. I have a feeling i will need to do most if not all of these to get it to fit.
-use the smallest diameter shaft possible 2" maybe a 1.5"
-rotate the pinion up 2 degrees
-raise the pillow block as high as possible
-extend the yoke for the intermediate shaft as far forward as possible
-cut of the lower link brackets on the axle, and rotate them pointing more downwards instead of straight back.
-get smaller diameter chromo links
-reduce the amount of uptravel
didnt S&N use a custom homebrew D44 front axel for the front Shaft?
Those are pretty thin maybe 1 1/4" and id think pretty strong. you could mayb even find a Chromo one?:redneck:
Just noticed my red star is back thanks mike.
It's hard to tell from the picture but it looks like a smaller diameter DS could be the ticket. Mine 1 3/4" and like Hip said many of them are 1 3/8".
or maybe reduce the uptravel on that side only? an inch would probably do it.
dana 50 long side shaft :awesomework:
if that ends up being the fix i have one i am pretty sure. free if ya need it.
i believe that's the fix the older sn d44 shafts didn't accept a 1350 joint
the dana 50 does you still have to get fancy for the spline mill part of a slip spline down and weld it on
My rig has S&N dana 44 driveshafts with 1350 joints in them. Strong as hell, but not meant for high speed thats for sure.:;
Is it a optical llusion or are you going to have to do some interesting exh work on the pass side?
I got the floors, firewall, dash, and roof done, i need to make tabs and some slight trimming here and there.
Nice dash.. how much for a copy!! (seriously, I'll need one some day as well).
Good work, comming together nicely :beer:
PM sent mark.
Got some carboard skins on it, not sure if i will keep the round wheel well in back, i may cut it square to match the front. Ran out of time, but will get back on it this weekend. Not much left before the final teardown.
