Balling on a budget 96 xj build
Finally found a steal on a matching set of one tons.
ridered3 said:
Glad to see an update. I like cheap-ish garage builds.
Thanks man with work and kids it makes it hard to get anything done. Hoping to have it back while again by the first of September
A few updated picture of some new progress
If it's not too late, I would recommend adding a piece of tube for the bolt to go through between the upper and lower steering arms. Only having the bolt in there really isn't giving much, if any, extra strength by utilizing the factory steering location in conjunction with the new steering arm.
Thanks for your comment. There is a piece of chromoly between the two that is welded. Plus I made a guss to go between both top and bottom for extra support
Finally got my tires in just need to find me some 16.5s
Update it been a little while since I posted I finally got it done took it around the block and some how bent my right rear ORi which is supper awesome. So I got that fixed then redid both rear shock mounts.
