Battery Question
It wont take long to use up that battery. How did you hook the winch up? If you are going to add to the existing bolts, get the longer ones with the lead insert. Be sure to put the winch on the closest one to the battery, so it will not overload the bolt. The engine load will be less than the winch motor.
I have the GM longer bolt with the insert. It's hooked up and ready to go. Hopefully I'll try it out this weekend. :awesomework:
