Fuel injected 460 Windsor I have at the dyno shop now. Big block in a small block package!1TONTJ said:
Are you running Trick Flow high ports also?Jwhit55 said:
mike2.5 said:Are you running Trick Flow high ports also?
thats the only place it should be. Out front ahead of a ChevyElliott said:Someone put your distributor on the wrong end of the motor!
maybe but my motor will pull 4wheel high rangetonybolton said:That's so you can work on'em easier.![]()
mike2.5 said:Fuel injected 460 Windsor I have at the dyno shop now. Big block in a small block package!
