C
Cole
Guest
That thing sounds Nasty. I can't wait to see Big Al giving it Hell.
Juan_Hong_Loe said:Kelly, if its thick enough material and precision ground surfaces, shouldn't have the need for a gasket other than maybe some silicone. I took a couple of courses of machine tool at the local community college and precision grinding was one of the courses. Man did it suck! Watching that grinding wheel go back and forth! On another note, if you grind two pieces of metal fine enough you can push those surfaces together and twist them and they'll stick together. Kinda weird. Wouldn't have believed it till I saw it. :****:
Was just worried about weld warpage and lack of sealing. No worries on reflattening it. I like the idea and will most likely use it.Juan_Hong_Loe said:Kelly, if its thick enough material and precision ground surfaces, shouldn't have the need for a gasket other than maybe some silicone. I took a couple of courses of machine tool at the local community college and precision grinding was one of the courses. Man did it suck! Watching that grinding wheel go back and forth! On another note, if you grind two pieces of metal fine enough you can push those surfaces together and twist them and they'll stick together. Kinda weird. Wouldn't have believed it till I saw it. :****:
blacksheep10 said:Was just worried about weld warpage and lack of sealing. No worries on reflattening it. I like the idea and will most likely use it.
wontwork said:Weld then machine it off.
blacksheep10 said:No worries on reflattening it. .
